LinkBack (1) Thread Tools
Old 04-09-2008, 05:30 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
StXFoo's Avatar
Trader Rating: (33)
StXFoo Level 4StXFoo Level 4StXFoo Level 4StXFoo Level 4StXFoo Level 4
Default Looking into 8" subs
I just got a sub box (Smokin' VR4's quadruple 8" sub box) and now I am looking at subs and amps. I mainly listen to rock, with a little bit of hip hop/rap. Some jazz and classical as well (I know, all over the place). Anyway, I have heard good things about Polk Momo MM2084/MM2084DCV (the difference is single vs dual vc's). They are only 200RMS/400Max @ 4ohms and seem to fit the type of sound that I listen to (from user reviews). Running 4 of them, what amp/s should I use? I have considered getting a bigger amp and running these guys in parallel but I am not exactly sure about that.
Any help would be appreciated.
StXFoo is offline   Reply With Quote
Old 04-09-2008, 08:00 PM   #2 (permalink)
The Student
LeigerReign's Avatar
Drives: 92' VR$
LeigerReign Level 7LeigerReign Level 7LeigerReign Level 7LeigerReign Level 7LeigerReign Level 7LeigerReign Level 7LeigerReign Level 7LeigerReign Level 7
Default Re: Looking into 8" subs
Run them with a powerful mono, the alpine 800watt rms should do. I forget the model. And as far as the wiring, run them like a christmas light string. Semi parallel, semi series. its a good, consistent setup because it keeps the ohms at 4 on the amp and allows for good power to the subs so they arent underpowered. Those subs you were looking at are nice, i like them. I might also check out the Infinity 8" Subs. They might not hit quite as hard, but they will definitely have a crisper, cleaner sound. Especially on the high end. Anything else, dont hesitate to PM me
LeigerReign is offline   Reply With Quote
Old 04-10-2008, 08:31 AM   #3 (permalink)
StXFoo's Avatar
Trader Rating: (33)
Solid - thanks for the heads up.
Old 04-10-2008, 11:13 AM   #4 (permalink)
autopsycho's Avatar
autopsycho Level 3autopsycho Level 3autopsycho Level 3autopsycho Level 3
STxFoo, may i suggest Image Dynamics to you. I have been using their products for a couple of years now, and i can guarantee you will not find subs that reproduce better bass than them for their cost. Theyre tight and fast with bass.
Try out this link, the ID 8 D2 V.3 is your sub of choice.
Image Dynamics USA - Products - Idv.3
I have my IDMax 10" on the way for my new install. Earlier put two 12"s IDMax on a friends car powered by 1100watt monos on each... lets just say his car is friggin boomy.
Also check out their range of Q amplifiers, my first stock with the amps are arriving as they launched them recently, will give some feedback on that soon.
autopsycho is offline   Reply With Quote
Old 04-10-2008, 08:02 PM   #5 (permalink)
Will work for mods
Chain's Avatar
Drives: 95 3000gt N/A
Chain level 6Chain level 6Chain level 6Chain level 6Chain level 6Chain level 6
Image Dynamics is a very nice sub for the price.
Just a little more bang for the buck is Treo subs.
OMG you will be blown away. The SSI 8 ported will sound like 2 12's
If everyone like the same thing & had the same taste,
we would all be dating the same girl.
Chain is offline   Reply With Quote
Old 04-11-2008, 02:01 PM   #6 (permalink)
StXFoo's Avatar
Trader Rating: (33)
I have a sealed box. Though, I guess I could port it easily...oh well - I couldn't pass up a deal on those Polks so I went ahead and got them. Now is to find an amp....
Old 04-11-2008, 03:17 PM   #7 (permalink)
Paid Member
973000GTSL's Avatar
Drives: 97 3000GT VR4 Black
973000GTSL is an unknown quantity at this point
I might be the only one, but i really like the way, and if you can find them, 3 JL w6's sound you wire them to a total load of 1ohm, they sound awesome, and punch pretty good. I am dating myself, but back in 1999, they were the shit
1997 3000GT SL Black (sold)
1997 3000GT VR4 Black
13.48@101 stock
RoJa R2-5 18X9 w/Dunlop Direzza Sport Z1 Star Spec
KN FIPK
Stillen Rotors
IPS quad tip catback
IPS 3" DP
Mods to be installed
Apexi AVC-R
Walbro 255 hotwired
parts for sale
3SX Underdrive Pulley with gatorback belt $130 shipped
973000GTSL is offline   Reply With Quote
Old 05-06-2008, 08:37 PM   #8 (permalink)
jlfx car audio's Avatar
Drives: 97 3000gt sl
jlfx car audio is an unknown quantity at this point
i love DD(digital designs) 1508 D4 i had 1 in my 3000gt with a orion 8002 on it and it was amazing i would put it up to any 2 mainstream 10"s on the market every install i have seen or done with any subs except DD in a car or hatchback with under 1000w does no more than 141db legal the 1 8" did 139.7 legal @ 42hz aqnd would play down to 34hz befor bottoming out it can stroke about 1.5"
jlfx car audio is offline   Reply With Quote
Old 05-08-2008, 10:37 PM   #9 (permalink)
Banned from Classifieds
smokinvr-4's Avatar
Drives: Smokinvr4@hotmail
Trader Rating: (100)
smokinvr-4 is an unknown quantity at this point
I personally would use JL or some FoCal polyglass subs, they should work pretty well in that box. Or maybe some diamond audio 8's.
I would use 8 ohm subs unless you have an amp that can handle a 1 ohm load, then go for 4ohm.
There certainly are not as many manufacturers that make 8" subs as there used to be.
Let me know what you come up with....
smokinvr-4 is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f6/looking-into-8-subs-414867/
Posted By For Type Date
Looking into 8 This thread Refback 04-09-2008 12:57 PM
