I am using this fix right now on my OEM tensioner and OEM timing belt.
BUT
On my new engine I am going with a solid tensioner and a kevlar belt.
Reasoning.
My Logic
I don't trust OEM tensioners anymore. I have personally seen a couple OEM tensioners fail within a few miles of being installed. It is hit or miss even with the OEM ones. My assumption is that it is due to them sitting on a shelf rotting away. Those OEM tensioners are under high pressure. Sit them on a shelf for 10-15 years and then add load and heat to them. The seal gives and they fail.
My issue with the OEM fix is that does it still apply after years of belt stretch? Even adding in the spacer to the tensioner, at some point down the road the belt will stretch far enough that even the washer would not apply enough to case the belt to not slip. Granted the only way to test this would be compare a brand new OEM belt to one that had 60K+ miles on it and see what the stretch was.
I am switching to the solid/kevlar as I don't have to worry about the solid tensioner failing. The kevlar belt will not stretch and is XXX% stronger than the stock belts.
As for the comment
"expansion of the engine will force something has to give"
Well my cam shafts don't have bearings so pretty sure they will not be what wears out. if anything the extra force will be applied to the T-belt idler or tensioner pulley bearings instead of belt stretch.
Guess I have more faith in steel roller bearings then a hydraulic tensioner.
